سعود معتمد
2023-09-22 20:12
Has anyone in the group experienced the issue of oil leaking from the spark plug area in the 2013 Touran?
أحمد عوض
أحمد عوض2023-10-13 18:44
Mine too.
أنيس عبدالرحمن
أنيس عبدالرحمن2023-10-06 20:26
The oil leakage from the spark plug is due to a damaged rubber gasket underneath it. This causes oil leakage and cylinder misfire issues. It's recommended to replace the timing chain at the same time. The damage to the rubber gasket might be related to high engine temperatures. To prevent this, make sure to clean the radiator and use high boiling point antifreeze.
عمر لاويل
عمر لاويل2023-10-02 01:56
Search for "EA111 spark plugs oil" on TikTok for detailed explanations.
