أحمد ربيع
2022-10-14 23:02
Has anyone experienced the engine warning light flashing and the vehicle shaking? It gets better after a while.
Comments( 7 )
حسن نظيف
حسن نظيف2023-04-23 17:19
Throttle inspection
علي ذكي
علي ذكي2023-03-17 13:43
It feels like a cylinder misfire! How long has it been since you last changed the spark plugs?
علي فاتح
علي فاتح2023-03-16 23:35
There is a leak between the exhaust or intake pipe and the engine.
2
نايف مأمون
نايف مأمون2023-01-27 22:09
Spark plug
أنيس عبدالرحمن
أنيس عبدالرحمن2023-01-27 07:29
This might be due to the recent switch to National VI B gasoline.
عبدالله آدم
عبدالله آدم2023-01-17 18:23
How many kilometers has it been? Have you checked the spark plugs or the fuel?
فهد معتصم
فهد معتصم2023-01-01 09:34
Have you experienced this before? Is it because the car was parked for a long time?
Why did the engine warning light turn on and the D gear light keep flashing after driving my 2014 Honda City automatic on the highway for three hours?
14 model Middle East Land Cruiser has driven 150,000 km. Recently, when starting in the morning, the center differential lock light flashes. After driving for a while and restarting, the light stops flashing. Just completed a full maintenance and changed all oils and fluids. Has anyone else experienced this issue?
When I turn on the AC, it makes a noise... After a while, it gets a bit better, but when I stop the car, it starts making noise again... Has anyone experienced this? Thanks.
The 4LO warning light and the engine light on the Land Cruiser are both flashing.
4WD light is flashing, and the vehicle won't start.
Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
Why is my vehicle shaking a little while driving?
Have any of you experienced a situation where the engine shakes violently when you release the brakes while waiting at a traffic light? What could be causing this?
Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
