حسن تامر
2024-05-24 07:04
For the 2011 VW Touran with a manual transmission, it's generally recommended to use high-quality engine oil that meets the manufacturer's specifications. A popular choice is synthetic engine oil from brands like Castrol, Mobil 1, or Shell. Always ensure the oil meets the VW 502.00 specification for optimal performance.
علي ذكي
علي ذكي2024-05-29 17:46
I've used Mobil 1, and the oil consumption is a bit high, about a liter every five to six thousand kilometers. After doing a carbon cleaning and switching back to FAW-Volkswagen's black barrel full synthetic oil, the oil consumption is about the same, but it's quieter. It's almost 170,000 kilometers now.
عمر صباح
عمر صباح2024-05-26 18:51
Jinmei 040
أحمد ربيع
أحمد ربيع2024-05-26 12:18
Mobil Silver is enough, more powerful than other brands.
2
حسن عبد الغفار
حسن عبد الغفار2024-05-24 10:01
Jinmei or Chaojin 040, feeling great so far!
Which is better for SsangYong Korando engine oil, Mobil 1 or Kunlun KR9?
For a Mazda 3 with a 1.6L engine, you typically want to choose a high-quality engine oil to ensure optimal performance and longevity. Many users often recommend brands like Mobil 1, Castrol, or Shell. As for the viscosity, a common choice is 5W-30, but it's important to refer to your vehicle's owner's manual for the recommended specifications.
Can the 2019 Changan Yuexiang use Mobil 1 5W-40 engine oil?
Today, the maintenance technician suggested switching to Shell's Yellow Bottle motor oil, mentioning that Castrol's oil with cleaning features might cause more oil leaks. Has anyone used lower-quality oil before? Is it usable?
What engine oil is recommended for the Jinxuan 4B11? I've been using the original 5W30 mineral oil from the 4S shop for over 5 years (people say it's like gutter oil [lol]). I want to switch directly to fully synthetic oil. Any recommendations? Some say you should transition with semi-synthetic oil before switching from mineral to fully synthetic. Is this necessary for the Jinxuan?
Which synthetic engine oil do you use for the 2020 Tharu 1.4T model?
Which is better for fully synthetic motor oil, Castrol or Mobil?
Changan CS35 Plus, 2023 model, uses CTS-03.08.06. 0W-20 Changan-specific full synthetic oil. How many kilometers should it be driven before an oil change during maintenance?
For the 2023 Changan CS35 Plus, when using the CTS-03.08.06.0W-20 Changan-specific full synthetic oil, how many kilometers should the oil be changed during maintenance?
