نايف نادر
2022-03-12 06:44
سعود إياس
سعود إياس2023-04-13 10:22
The transmission fluid is only two liters.
عبد العزيز دين
عبد العزيز دين2022-03-24 00:08
Of course, you should change the transmission oil. For automatic transmissions, it's best to change it before 40,000 kilometers. For manual transmissions, the timing is more flexible.
رمضان علي
رمضان علي2022-03-13 08:51
You should change the transmission oil at 80,000 kilometers.
علي جليل
علي جليل2022-03-12 11:43
It is recommended to replace it at 60,000 kilometers.
20
