Does anyone know why my 2014 Touran, which has 140,000 km on it, sometimes has the D gear light flashing while driving and the accelerator doesn't respond? I have to turn off the engine, switch to P gear, and restart the car to drive again. What could be causing this?
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
Why did the engine warning light turn on and the D gear light keep flashing after driving my 2014 Honda City automatic on the highway for three hours?
4Does anyone know why my 2014 Touran, which has 140,000 km on it, sometimes has the D gear light flashing while driving and the accelerator doesn't respond? I have to turn off the engine, switch to P gear, and restart the car to drive again. What could be causing this?
5The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
6Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
7Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
8Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
9What should I do if the USB flash drive is not responding when plugged in?
10Hello everyone, my Peugeot 307's air conditioning isn't cooling, but sometimes after restarting, it cools again. What could generally be the problem?
