Can the 2013 base model Touran display the outside temperature?
My 2013 Touran won't start, and all the warning lights are on. Can anyone help?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
4Can the data such as water temperature and oil temperature be displayed?
5The clutch in the 2013 Touran manual feels heavy, and the car body shakes slightly with a small release.
6Can the 2013 model connect to a phone to play songs?
7The 2013 Touran automatic gearbox has oil leakage, and repeated attempts to fix it have failed!
8What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
9Are the seats in the base model only available in black?
10The outside temperature is 15 degrees Celsius, but it's hot inside the car without opening the windows. What's going on?
