The three common issues with the Touareg have been resolved: engine mount aging, differential noise, and fuel tank noise.
What is the fuel tank capacity of the 2017 T60 pickup with a 2.8T engine?
Has anyone encountered engine noise in a 2019 F150 with 60,000 km? The mechanic says it's a common issue and suggests dismantling the engine to fix the gears.
Foton Cummins engine, 2.8T engine having diesel entering inside, causing the oil dipstick to rise by two to three centimeters every few hundred kilometers. The high-pressure fuel pump has been replaced, and the injectors have been calibrated without any issues.
4Is the engine noise of the 2014 Volvo V60 a common issue? [Crying][Crying] Is it just because the car is getting old? Or is there a design problem with this model? [Shocked][Shocked]
5The three common issues with the Touareg have been resolved: engine mount aging, differential noise, and fuel tank noise.
6When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
7Touareg 3.0, after over 20,000 km, experiencing differential resonance when turning. The dealer isn't resolving it, saying it's a design flaw. The differential is smaller than before. Changing the differential oil can temporarily fix it, but the resonance returns after another 20,000-30,000 km. Do you guys have this resonance issue with your cars?
8Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
9My Rong Plus has been with me for three years, and it has clocked 60,000 kilometers. The gear shifter broke, the fuel tank cap is damaged, and today, the battery also failed. 😔 Feeling down.
10Hey folks, does anyone use 98 octane fuel? I filled up with a tank of 98 yesterday and noticeably felt the engine noise reduced. Is this just psychological? Let's discuss it! 😄
