The headlamp covers of my 2008 Touareg have aged, and the lights aren't very bright when driving on highways and country roads at night. Should I replace the entire assembly or just the lights at a modification shop? If I replace the assembly, will it be significantly brighter? And if I opt for modification, can the wiring handle it, considering the car is quite old? Thanks.
علي هادي2024-11-14 21:49
If there's a lens involved, it's likely the lens has aged. Simply changing the bulb won't have a significant effect. The best solution is to replace the lens. If the lampshade is aged, you can have it polished at a detailing shop, which can last for another two years.
