My car has reached 57,000 kilometers and I'm planning to change the transmission fluid and differential oil. If I want to do it at an external service shop, which brand is good to use?
Where is a good place to get the transmission fluid changed on a 2010 MDX? Thanks 🙏
How often should the rear differential oil for the RDX AWD be changed, and what brand is used? 😊
4How often should the transmission fluid be changed?
5How often should transmission fluid be changed?
6Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
7Hi everyone, could someone help me out? Where is the external transmission oil filter on the Acura TL? I'm getting my transmission oil changed, and the mechanic said this car doesn't have an external filter.
8Does anyone know how to maintain the transmission for the Pentium 8AT version? I've been asking the 4S shop for a long time, and they keep saying it's out of stock. Can I get it serviced at an external transmission repair shop? Just using gravity oil change, can other maintenance kits be sourced at external repair shops?
9Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
10My car has reached 57,000 kilometers and I'm planning to change the transmission fluid and differential oil. If I want to do it at an external service shop, which brand is good to use?
