خالد فرج
2024-08-26 22:51
Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
Comments( 6 )
سعود أمين
سعود أمين2024-10-17 19:35
The engine mounts need to be replaced.
2
سعود خالد
سعود خالد2024-09-06 11:50
This is an issue with the fuel quality. In the morning, when the car is cold, have someone listen outside; if the noise is still loud, avoid refueling at small gas stations. Stick to Sinopec or Shell gasoline for refueling.
علي ضربة بكوع إير
علي ضربة بكوع إير2024-09-04 11:24
Could it be the windshield wiper?
عبد العزيز ضربة بكوع إير
عبد العزيز ضربة بكوع إير2024-08-30 11:00
I also encounter it occasionally, not sure why.
عبدالرحمن لطيف
عبدالرحمن لطيف2024-08-28 17:28
Could it be an issue with the brake caliper?
محمد تامر
محمد تامر2024-08-26 23:48
Record a video and have a look.
Is it normal for the T8 to require manual regeneration every ten to twenty days after 10,000 kilometers of driving on low-speed, mountainous roads? After multiple regenerations, it fails and needs to be taken to the 4S shop for computer regeneration, and there's also a significant increase in the oil level. Can fellow car enthusiasts share their experiences?
During the rainy season, my car has been parked outside for the past few days. After starting the car and pressing the brakes, I hear water sounds from the chassis. I've checked the sunroof and there's no leak, also tested the floor, and it's fine. Could it be that the frame has taken in water? Can any expert analyze this?
The 2019 Yuexiang has a strange noise from the belt area when starting in sub-zero winter temperatures, but it goes away after a few minutes. After inspection, no issues were found. What's going on?
When starting a 2005 Prado 2.7 from a cold start or after it's been sitting for about half an hour, there's a strange noise. I've already replaced the starter motor, but the issue persists. Does anyone have any ideas on what might be causing this?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
Has anyone experienced a metallic knocking sound when starting the 2024 Cayenne? I've been to the 4S shop several times but they couldn't find the source.
The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
Hey everyone, when I'm driving on the highway, there's a strange noise coming from under the steering wheel. It's not constant, just on and off, and it's really annoying! I've been to the dealership, but they couldn't completely fix it. Has anyone else experienced the same issue?
Volkswagen Volkswagen Touareg
Volkswagen TouaregAED 173,371 ~ 362,000Gasoline & Petrol
