عبد العزيز رومي
Nov 22
Hey everyone, I have a question. After shifting to P and turning off the engine, the car's system and air conditioning still keep running until I open the door. Is there a way to set it so everything turns off right after the engine is off?
Can the GS7 be set to automatically engage the handbrake when the engine is turned off? Has anyone set it up before?
Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
The car is difficult to start two hours after turning off the engine.
4For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
5After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
6The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
7Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
8My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
9Is the simulated engine sound in the RDX cabin too loud for you? Is there a way to turn it off or any other solutions to address this?
10Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
