خالد زايد
خالد زايد
Apr 29
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
خالد عبد عزيز
خالد عبد عزيز2024-11-30 12:04
Check if the coolant needs to be refilled.
2
حسين فاطمة
حسين فاطمة2024-11-29 23:15
The air conditioning is freezing, and the expansion valve is blocked.
أحمد فاروق
أحمد فاروق2024-11-21 19:47
Does the 2017 model with 110,000 kilometers have any oil consumption issues?
What could be the issue if the radiator fan of the Haima S5 only operates when a blower is used, and doesn't turn on even after driving for a long time?
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
Is anyone else experiencing the issue where the air conditioning vent actuator motor is broken and makes a clicking sound when powered on?
Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
Volkswagen Touareg
Volkswagen TouaregKWD 13,300 ~ 24,624Gasoline & Petrol
