Does the 3.0 Rui Enjoy have L2? It seems like if it just adds rear-wheel steering for an extra 100k, then it might not be worth upgrading to the Rui Zun. Is it necessary to spend more for the Rui Zun?
I just went out for a drive, and it seems like there's a problem on the way back. Is there anyone who knows about cars that can listen and tell if it's an engine issue? It's the holiday season, how should I fix it? (Mainly worried about further driving damaging the engine.) The specific situation is that on the way back, there was a noise indicating a fault, but no warning light came on. Then during two turns, the steering suddenly locked and the car stalled. Since I wasn't far from home, I drove a bit more and parked at home.
Can version 3.1.9 be upgraded? It seems that versions 3.0.3 and 3.1.2 were pulled back just a few days after their release. Version 3.1.10 was just released a couple of days ago and hasn't been pushed out yet. Currently, version 3.1.9 is being pushed in China. In the U.S., 3.1.9 was pushed out in early July, and it has been available in Europe for about a week. According to U.S. car enthusiasts on forums, some vehicles experienced a flickering issue with the 360-degree surround view in versions 3.0.3 and 3.1.2, where the screen would briefly go black and then light up again. After upgrading to 3.1.9, the issue was significantly alleviated during the first week, with flickering still occurring but only going black for 0.2 seconds and then automatically recovering, not affecting usability. However, the results after one week were not satisfactory, with the 360-degree surround view showing more frequent "camera unavailable" warnings than before, still severely affecting use. Yet, some car owners reported never encountering this issue (even with the problematic 3.x versions), so it might be related to a specific batch of parts or the vehicle's personalized settings. Have car owners in China noticed this issue after upgrading, or are there any other problems?
4I have a couple of minor issues with my Touareg 3.0, wondering if anyone else has experienced the same: 1) After refilling the windshield washer fluid, it leaks onto the ground. The mechanic suggested that it might be a crack in the connecting hose, causing the fluid to spill out. It doesn't affect usage. 2) Occasionally, when driving at low speeds in traffic, there's a slight squeaking sound when turning the steering wheel. It doesn't happen all the time and doesn't seem to have much impact.
5Is it necessary to put a protective film on the black Zeekr 001? Guys, the expensive ones seem not worth it, and I'm worried the cheaper ones might be hard to remove later. How did you guys decide?
6Does the 3.0 Rui Enjoy have L2? It seems like if it just adds rear-wheel steering for an extra 100k, then it might not be worth upgrading to the Rui Zun. Is it necessary to spend more for the Rui Zun?
