Hey folks, sometimes the 2006 model jerks a lot when starting. Could it be a transmission issue?
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
Hey guys, I have a question about the 2006 Peugeot 206 1.6 with the semi-automatic transmission. When I put it in reverse gear, the reverse lights don't come on. What could be the issue?
My car has a weird problem. Sometimes it takes two tries to start. What could be the issue?
4Have you ever experienced occasional jerking with the 2.4 transmission? What could be the issue?
5When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
6Hey folks, did the old Touran undergo a transmission upgrade starting in 2015?
7What could be the issue if there's a jerking sensation when refueling?
8Does upgrading the system at a 4S dealership help with the jerking issues of the MG ZS 2020 model's transmission?
9Hey folks, how's the Wuling Xingchi? Does it have a lot of minor issues? Is the maintenance expensive?
10My 2019 MG ZS 1.5L automatic jerks when accelerating, and sometimes the check engine light comes on. After stopping for a while, the light goes off. It starts happening once the speed hits 40 km/h. What could be the issue?
