عبد العزيز أبو بكر
2024-08-19 11:31
When driving the Tiida, there's always a rolling sound like a water bottle moving back and forth, but there aren't any bottles with liquid inside the car. What could be causing this?
فرج عبدالرحمن
فرج عبدالرحمن2024-11-19 18:30
I've also noticed this issue. Could it be the fuel tank making noise? Have you resolved your problem?
علي يحيى
علي يحيى2024-09-01 09:31
The rear seat has water leakage.
علي بدر
علي بدر2024-08-29 16:53
Does it have a sunroof? Check under the floor mats to see if the carpet is wet. Is it the sound of water flowing? If so, it might be due to a blocked sunroof drainage causing a leak.
سعود ياسين
سعود ياسين2024-08-20 15:34
I have a 2021 Tiida. When the fuel tank is full and it goes down to about two-thirds, I occasionally hear a sloshing sound from the back when driving on rough roads. It seems like the fuel is moving around.
أحمد نور
أحمد نور2024-08-19 13:15
Where exactly is it? Let's rule it out first.
