When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
What could be the reason for a 2015 car making squeaking sounds when driving on uneven roads?
The rear bed of the T60 shakes a lot on uneven roads. What's going on?
Anyone experiencing rear axle noise? The rear wheels aren't splayed, and there's no looseness, but on uneven roads, there’s always a rattling sound from beneath the rear seat. Does anyone know what the issue might be?
4When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
5Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
6Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
7When the Sportage makes a thumping noise over uneven road surfaces, what's the issue?
8When the car's rear window glass closes to the top and then immediately slides down, what could be the issue?
9Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
10When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
