What is the best method to replace the transmission oil for an old Nissan Tiida with a 4-speed automatic transmission?
Which engine oil is best for the 2019 2.0L Outlander, and what is the oil filter model?
What's the average fuel consumption for an automatic Nissan Sunny?
What could be the reason for the idling vibration in a Nissan Sunny manual transmission? I've replaced the spark plugs, but it hasn't solved the issue.
4Do I need to change the transmission oil for a 2016 Skoda Rapid, automatic, 6-speed?
5How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
6Is the 4-speed automatic transmission (4AT) in the Kia Pegas the same as the one in the Changan Eado DT? Please advise.
7Is it necessary to change the transmission oil at 100,000 kilometers? I'm worried that the new oil might not be as good as the original old oil inside.
8What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
9How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
10What is the best engine oil for H2?
