عبدالرحمن طب
2024-10-27 11:15
Replacing the transmission oil on a Tiida 4AT and removing the oil pan, if the technician drops a nut and it doesn't align with the bolt, leading to the removal of the valve body, will it cause any issues with the transmission?
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
Navara 2019 model, currently has over 60,000 kilometers. When changing the spark plugs, there was oil in the cylinders. The 4S technician said the valve cover needs to be replaced due to internal leakage and should be replaced together. I want to ask everyone, is this a common issue with the Navara?
Do I need to remove the oil pan to change the oil?
Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
After changing the transmission oil at 80,000 km on a 2014 Tiida, there is a fluctuation in the RPM from 2000 to 2200 when driving at around 120 km/h, and the car feels jerky. I went to the 4S shop, but the transmission didn't report any errors. Has anyone else experienced the same issue?
