سلمان مجدي
2024-10-13 21:39
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
أحمد نور
أحمد نور2024-10-15 03:45
The garbage truck was completely outperformed by my Bora.
حسن مدرسي
حسن مدرسي2024-10-14 17:06
How much did you pay for this car on the road?
عبد العزيز ثاني
عبد العزيز ثاني2024-10-14 16:23
To determine if the car is veering off its path, you need to test it on different roads. If the road is uneven, it might also cause the car to veer. If the car still veers after changing roads, it's recommended to get a wheel alignment to identify the cause and make adjustments. The cost is around 100, and the problem should be resolved.
أحمد نور
أحمد نور2024-10-13 22:39
This isn't about wheel alignment, don't mess around. It actually doesn't have any impact. If you're a perfectionist, just go get the steering wheel realigned or something.
After changing to new tires, the steering feels heavier. I always used Continental CPC2, but switched to Goodyear Assurance (also did a wheel alignment). It doesn't veer off course, but the steering feels heavier, and the accelerator is also heavier. For those who've changed tires, how do you feel about it? Also, a reminder: wheel alignment is a maintenance service, not mandatory. If you choose to do it, make sure to check the shop's equipment and skills. I feel it wasn't really necessary this time.
The steering wheel is not straight, but the car doesn't drift. How can I fix it? Thanks.
I bought it last month, and now the steering wheel pulls to the right while driving straight. Has anyone else encountered this issue?
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
Do you have the issue where the steering wheel is straight, but the car veers to the left?
Do you also have to slightly turn the steering wheel to the left when driving straight on the road?
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
Hey guys, when my Xiao 6 reaches 130 km/h, the right front wheel starts shaking. The faster I go, the more it shakes. But when I let off the gas and drop below 130, it stops. What's the issue?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
