حسن جل
2024-11-06 20:35
Hey everyone, I have a 2012 Tiida, and recently it's been acting up. Sometimes when I press the accelerator, it jerks a bit. Today, while coming out of the underground parking, the engine revved but the car wouldn't go up. I had to reverse back to the lower platform and start again to get up. Does anyone know what might be causing this?
حسن مكتوم
حسن مكتوم2024-11-07 09:58
It's about the transmission.
فهد باهر
فهد باهر2024-11-06 22:28
Is there any fault code showing? It feels like the transmission might be broken. You should probably take it to the repair shop and have it checked.
أحمد نور
أحمد نور2024-11-06 21:44
Not quite sure, but it feels like the transmission is slipping.
Does your car's transmission have significant jerking? When I shift into reverse, I can hear a noticeable clunk inside the car. Is this a serious issue?
Before the Gladiator was launched, I had pre-ordered the Raptor and waited for a long time. When the Gladiator was launched, I expected the price to be 38. If it was 38, I wouldn't wait for the Raptor. But it turned out to be 50.99, so I got the Raptor instead. Now the Gladiator is 38! What was the point!
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
Hello fellow car enthusiasts [smile] I have a professional question for the expert mechanics out there! I have a 2013 MG3 with a 1.3L manual transmission. Today, I wasn't in a good mood and drove with the engine revving at 3500 RPM! I was shifting gears up and down intermittently for over a minute at this 3500 RPM. Will this cause any damage to the engine? It was under hot engine conditions. I hope some expert mechanics can help me out, thanks a lot (^_^)
Why does my Sunny manual stall frequently with jerking? I never had this issue before with a manual. Could it be that the clutch needs replacing?
Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
The car's infotainment screen goes black, but when I switch to reverse, it lights up without displaying anything. [facepalm]
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Today gave me a scare! The light was green and suddenly a fault code appeared, and the car wouldn't move! Not sure what happened. I didn't have time to take a photo.
