Everyone's saying this transmission isn't good. It's said to have common issues. Friends, is this transmission really not durable? I don't drive aggressively, and I'm looking to buy a hatchback or a two-box car. I don't want one with a particulate filter, don't like turbocharged engines, and not a fan of dual-clutch transmissions. Right now, Tiida seems to be the only one without a particulate filter. I'm just concerned about its transmission.
Comments( 11 )
Hi everyone, how's the quality of the H7? Is it worth getting a second-hand one? The value for money seems good, but I'm not sure about its durability.
Is the transmission of the 1.3T version of the Jeep Renegade the same as the old one? Are there any improvements in comparison, and is the failure rate high? I'm considering getting the 1.3, but there are so few four-wheel-drive options. I also don't want a naturally aspirated engine.
I changed the transmission oil at 40,000 km at the 4S shop, and now at 100,000 km, I'm planning to replace it for the second time. I'm considering using Shell CVT transmission oil. Has anyone tried it? Is it okay to just clean the metal filter?
4Regarding the cost-effectiveness of Jetur X90, Chery Tiggo 8, and Geely, which one is higher? I'm a newbie and don't really understand.
5Hi everyone, could someone help me out? Where is the external transmission oil filter on the Acura TL? I'm getting my transmission oil changed, and the mechanic said this car doesn't have an external filter.
6Hi everyone, can the Toyota CVT with a launch gear handle aggressive driving? I'm quite heavy and like to use a lot of throttle. I've seen online that it can be hard on the transmission.
7Everyone's saying this transmission isn't good. It's said to have common issues. Friends, is this transmission really not durable? I don't drive aggressively, and I'm looking to buy a hatchback or a two-box car. I don't want one with a particulate filter, don't like turbocharged engines, and not a fan of dual-clutch transmissions. Right now, Tiida seems to be the only one without a particulate filter. I'm just concerned about its transmission.
8Does the 2024 Highlander's particulate filter still get clogged? Fellow car enthusiasts, is your particulate filter still getting clogged? I've heard that the materials used now are better, so the chances of clogging are lower. I'm considering just replacing it with an empty shell to avoid future headaches.
9Hey everyone, how many kilometers before you need to change the fuel filter? Does it matter if I don't use the original one?
10I went to the Toyota 4S store yesterday to check out this car. The exterior and interior are both acceptable. I'm just a bit concerned about one thing: the particulate filter is located in the middle section of the exhaust, which is a bit far from the engine. Theoretically, since it's a naturally aspirated hybrid engine, the operating temperature is lower and the filter is farther from the engine. Wouldn't the particulate filter be more prone to clogging? What do you experts think about this issue?
