حسين ميسور
2024-04-02 17:29
Why does the Ford Territory suddenly lose power and then accelerate again multiple times when normally accelerating to 60 km/h?
سعود فخريل دين
سعود فخريل دين2024-10-31 14:49
Scary.
حسين ميسور
حسين ميسور2024-09-05 21:37
Does anyone know how to solve the issue of severe jerking during automatic gear shifts? The service center hasn't been able to fix it despite several maintenance visits!
محمد فخرو
محمد فخرو2024-04-27 07:47
Wow, just when I wanted to learn about this car, I saw this [I want to be alone].
نايف حارثي
نايف حارثي2024-04-25 15:24
Slipped
Is it normal for a 2015 model 2.0L automatic transmission car to have the RPM around 1300 at 60-70 km/h, and when slowing down for a turn then accelerating again, the RPM suddenly rises and acceleration is slow, with the RPM at 1600 to 1700 at 60 km/h and not dropping, and sometimes after turning off the engine and restarting it behaves normally?
Whose car would behave like this, suddenly losing power while accelerating and then gaining speed again?
What is the 0-100 km/h acceleration time for the G90?
1.4T T-Cross, there's a buzzing sound when accelerating above 60 km/h, but no sound when not accelerating. Looking for answers to the issue.
Is it normal for the Sunny to have loud noise at around 60 km/h?
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
