Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
The car battery is dead, how to lock the car doors? Currently, the mechanical key can only lock the driver's door.
4The car key doesn't automatically lock or unlock when it's nearby. Does anyone know why?
5Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
6Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
72014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
8My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
9The inner button on the passenger door isn't working, but it can be opened using the screen controls and from the outside. What could be the reason for this?
10How to set up the Ariel so that the front passenger or rear passengers can open the door without the driver needing to press the unlock button? Please help!
