Where is blocked if water leaks from the bottom of the A-pillar during a car wash?
There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
4What's going on with the Skoda Kodiaq A-pillar leaking water when it rains?
5What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
6Where should I apply sealant if there's a water leak in the engine compartment? 🤔
7Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
8Any good ways to remove the water streaks on the car door from the left side mirror after a car wash? Thanks!
9Hi 5008 owners, I accidentally left the passenger window open during an automatic car wash today. Is there a chance that water could get into the transmission? The car is only nine months old. 🙏
10What's going on with the water leak from the A-pillar in the 2019 manual luxury version?
