علي شادي
2024-09-21 23:36
When releasing the accelerator, there's a rattling metal friction sound. What could be the issue?
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
I have a 2016 S5 manual, and recently the engine noise has become quite loud, with a rattling sound. The mechanic said the tensioner bearing is broken. When I'm driving and press the accelerator, there's a ticking sound that gets faster the more I press it, but it stops when I release the pedal. Does anyone know what might be happening...?
Is there a rattling noise from the chassis when accelerating with the H7? Has anyone experienced the same issue?
What could be the issue if there's a clicking sound from the steering wheel when idling?
When the 2018 F150 XLT makes a rattling noise when you release the accelerator while it's cold, but the sound disappears when the vehicle warms up, it could be due to several reasons. Since you've already replaced the timing components and the turbo, you might want to check other areas such as the exhaust system, heat shields, or engine mounts for any loose parts or issues. It's also advisable to consult a mechanic to diagnose the problem accurately.
1.4T T-Cross, there's a buzzing sound when accelerating above 60 km/h, but no sound when not accelerating. Looking for answers to the issue.
My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
Does anyone else hear a rattling sound during the start-up acceleration of the 2023 Mini S? What could be the cause?
I got my car in August 2024, and when the left wheel goes over rough roads, there's a metallic clanking noise. What could be the issue?
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
