The engine warning light is on for my 2019 car, and the diagnostic says the catalytic converter is aging. What should I do? Do I need to replace it with a new one?
Does the 2019 SAIC Maxus T60 diesel have a catalytic converter?
Fuel not getting through, no power, engine warning light is on. What's the situation? Is it the fuel injector or the catalytic converter?
The mechanic replaced the catalytic converter for me, but now the car lacks power when climbing and accelerating. Do I have to buy an original catalytic converter? The original one is quite expensive, over 5000.
4Is it true that all used 2019 Changan Yuexiang automatic models are from Liandongyun? How can you tell if the catalytic converter has been tampered with?
5I installed a new large-screen navigation system today, and after installation, the center differential lock light is on, the engine warning light is on, and the traction control light is on. What's going on? Help!!?
6Do I need to activate the system again after upgrading to the new system?
7Have any fellow car enthusiasts encountered a situation where the catalytic converter has minor cracks, causing occasional exhaust emissions to go uncatalyzed and triggering the emission warning light? The mechanic mentioned this. I regularly use Carpol's catalytic converter cleaner, Liquid Gold, etc., so there shouldn't be a carbon buildup issue.
8Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
9The engine warning light is on for my 2019 car, and the diagnostic says the catalytic converter is aging. What should I do? Do I need to replace it with a new one?
10Hello fellow car enthusiasts! I bought my ZS at the end of 2019, and it has driven over 120,000 kilometers so far. Recently, it started showing a fault code indicating that the catalytic converter efficiency is below threshold. Has anyone else replaced their catalytic converter? What was your experience? Thanks!
