The battery life for a Territory PHEV (领界铂领) typically varies, but having to replace it twice in three and a half years seems unusual. It's worth checking if there are any underlying issues affecting the battery's longevity or if the specific usage patterns might be impacting its lifespan.
Comments( 6 )
I took a test drive in a Tesla and got really hooked. Today, an EV friend told me that batteries have a calendar life, and even if you don't use them much, they generally reach their limit in about ten years. Since the Model Y hasn't been out for many years, no one can really answer this. Do any of you with Model S, especially the older ones, have any issues with battery usage?
I have a couple of minor issues with my Touareg 3.0, wondering if anyone else has experienced the same: 1) After refilling the windshield washer fluid, it leaks onto the ground. The mechanic suggested that it might be a crack in the connecting hose, causing the fluid to spill out. It doesn't affect usage. 2) Occasionally, when driving at low speeds in traffic, there's a slight squeaking sound when turning the steering wheel. It doesn't happen all the time and doesn't seem to have much impact.
4Hello everyone in the Leapmotor community, I have a question. Can you unplug the charging gun during slow charging at home? This morning at 6 o'clock, while I was sleeping and the car was charging, my father needed to use the car. He directly unlocked and unplugged the gun to drive away. This raises my doubts: Can the Leapmotor C11 pure electric model be directly unplugged during slow charging? First, does this operation pose any threat to personal safety? Second, will this affect vehicle safety? Third, will it impact the battery? If it's an incorrect operation, how should one correctly stop using the car during charging?
