نايف مستعصم
2024-06-13 17:35
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
When I press the accelerator while the car is stationary, it jerks like a newbie driving a manual car. But if I let it coast a bit after releasing the brake and then press the accelerator, it runs smoothly. Does anyone know what might be causing this? ╮(╯_╰)╭
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
What could be the reason for the headlights and brake lights turning on by themselves at night?
Hey everyone, does anyone know why a car would suddenly brake uncontrollably for a moment while driving normally, and then go back to normal? Any ideas?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
There is a "clunk" sound when applying the brakes to stop.
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
