Is it advisable to buy a 2019 Ford Territory with the highest trim level if it keeps triggering the alarm automatically all day until the battery is drained?
For the 2019 GS5270T model, if the vehicle randomly triggers an alarm as if someone is trying to open the door without a key, but no one actually does, and it happens multiple times a day, how can this be resolved?
Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
4Is it advisable to buy a 2019 Ford Territory with the highest trim level if it keeps triggering the alarm automatically all day until the battery is drained?
5In March 2021, I had a 2020 model of the Leading Version. A few days ago, while driving on the highway with the AC on, everything was fine for about an hour. Then, it started getting hotter inside the car. When I checked, the air coming out of the AC vent was disappointingly weak. Usually, setting it to level 1 is more than enough to keep things cool, and sometimes I even have to turn it off for a bit. But this time, even when I turned it up to levels 3 or 4, the cold air was still too weak. Finally, I set it to the maximum, which was barely acceptable. At the same time, the noise from the electric fan became increasingly louder. Later, when I turned it back to levels 1 or 2, there was no airflow at all. Has anyone else experienced a similar issue? How should I resolve it? I would appreciate any valuable suggestions. Thank you.
