سعود جل
2021-12-26 19:15
I parked my Territory in the mall's underground parking. After paying the parking fee and stepping on the gas to go up, it suddenly couldn't move. The car started shaking like "tut tut tut," and it felt like something was stuck in the front. The engine seemed to lack power.
Comments( 15 )
حسن أمين
حسن أمين2023-12-14 14:13
Bro, did you get it fixed? Seems like a common problem.
عبدالله لهب
عبدالله لهب2023-12-08 01:53
I had the same issue. The transmission valve body was faulty, and the computer couldn't detect it. They replaced the battery and catalytic converter, but it didn't solve the problem. Finally, they found out it was the transmission valve body, replaced it with a new one, and it was fixed. It's a common issue and quite frustrating. Luckily, it happened while still under warranty, so I didn't have to spend much. But if it's out of warranty, it would cost around 7000 at the 4S shop.
شرف علي
شرف علي2023-11-28 21:53
Changing the engine oxygen sensor fixed the issue. I even bought two spares just in case.
حسن برهان
حسن برهان2023-11-24 19:53
I sold my car.
خالد مطلب
خالد مطلب2023-11-12 22:43
So many people are having the same issue, I really regret buying this thing. I initially considered the Volkswagen T-ROC but didn't get it because of a two-month wait, and ended up buying this instead.
علي صارم
علي صارم2023-08-06 00:51
Valve body issue! I had it happen once while going uphill. Now, I switch to manual first gear when going uphill, and it's fine!
حسن برهان
حسن برهان2023-07-27 19:19
My car had the same issue yesterday. First, it showed an engine fault. Then, when I accelerated, the engine revved to 3000 RPM but only went 80 km/h. At 4500 RPM, it only reached 100 km/h. I was 8 kilometers away from a service area at that time. I slowly drove to the service area, rested for about 20 minutes, and then restarted the car, and the problem was gone.
حسن زيلاخ
حسن زيلاخ2023-07-04 12:18
I also encountered this problem, and the 4S shop is going to replace the valve body for me.
حسن بشار
حسن بشار2023-06-24 14:08
I also experience the same issue sometimes when going uphill or downhill, where it feels like it's locking up.
سعود منذر
سعود منذر2023-06-21 11:04
Same here! How did you fix it, bro?
2
When I was driving my Toyota Yizhi with the CVT in D gear and stepped on the gas to 4000 RPM for overtaking, I suddenly felt a lack of power and then it sped up. They say this is the steel belt slipping, and driving like this can damage the transmission. I'm frustrated. What happens when the steel belt slips? Can any experts explain this?
2021 Outlander Vehicle Odor Issue. Background: Recently, the car was parked in an underground garage for a month, and the garage was somewhat damp. Situation: An unpleasant odor, like a musty and rotten smell, has started to accumulate inside the car. Self-assessment: I've checked the interior but couldn't find the source of the smell. I also replaced the air conditioning filter, and the air blowing out doesn't have any odor. However, as soon as the car is parked for half a day and I get back in, there is a strong smell in the cabin. The car has never been submerged in water or flooded before. Question: Has anyone experienced a similar issue and can provide some guidance on how to deal with this?
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
