وهاب خالد
2024-06-02 14:53
Hi everyone, can anyone tell me where the carbon canister solenoid valve is located in the Territory? A picture would be great. Thanks!
عبدالله مكتوم
عبدالله مكتوم2024-07-14 22:46
I changed it in the 4th year, and it's out of warranty.
عمر بكر
عمر بكر2024-06-18 11:21
I changed it under the left rear seat of my car in the second year. The dealership recommended the change! I got tricked. Originally it was a ceramic part, and they replaced it with some aluminum alloy thing! After checking carefully, I found no residue inside and regretted it. [I want to be alone]
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Could you please tell me where the remote signal receiver is located in a Hyundai Accent? Thank you.
Could anyone tell me where the AUX port is located in the 2008 Mazda3 hatchback?
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
Hey expert, could you please tell me how to use the Jimny's differential lock and where the switch is located?
Could anyone tell me if the 19-inch wheels on the S come with hubcaps? If they do, what do they look like when removed? Any pictures? Thanks!
Does anyone know why the passenger side window switches in the ZS model are not working? Is there a switch somewhere that can control them? A picture would be great, thanks 🙏💡
Where is the Kia Sportage's charcoal canister purge valve located?
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
