محمد عرفات
محمد عرفات
Dec 13
Have you experienced any issues with the tire pressure sensor?
Comments( 6 )
خالد عبد الناصر
خالد عبد الناصر2024-01-20 09:46
The sensor rotated; just turn it back to its original position.
نواف عبدالله
نواف عبدالله2024-01-03 08:42
Kick it a few times, add some air, and then release some.
علي عثمان
علي عثمان2023-12-31 23:36
When repairing a tire, if the sensor's position and direction are rotated, it should be fine once you rotate it back to the correct direction next time.
حسن تاج
حسن تاج2023-12-26 21:35
The battery is dead.
عبدالله أمينة
عبدالله أمينة2023-12-24 22:18
Sorry, could you please provide more context or details about the issue after tire repair? This will help me translate it accurately.
حسن خد
حسن خد2023-12-19 16:37
I haven't encountered it.
Have you guys ever experienced the ABS, four-wheel drive, engine, parking, and anti-skid lights turning on? What's the situation? Is it a sensor issue or something related to the ABS?
Have you experienced any sunroof leaks with your Jeep Liberty? How did you resolve the issue?
Does the Hyundai Accent have a tire pressure monitoring system?
Hey folks, have you experienced any increase in engine oil volume with your Yizhi? What other issues have you encountered?
Have any of you experienced issues with CarPlay not connecting? I want to know how fellow car enthusiasts have resolved this issue.
The tire pressure monitoring sensor is broken.
Do you have any recommendations for tires and wipers?
Does Cetus Luxury have a tire pressure display?
Ford Territory
Ford TerritorySAR 100,798 ~ 130,755Gasoline
