Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
Hi fellow car enthusiasts 😄, do you know where the external transmission filter is on this car? Couldn't find it when changing the transmission oil. Thanks 🙏🙏
How many liters of oil does a Mazda 2 automatic transmission take for a gravity oil change?
4Do I need to remove the oil pan to change the oil?
5How do you guys change the transmission oil, gravity or circulation?
6Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
7Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
8Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
9Is it advisable to buy a 2019 Ford Territory with the highest trim level if it keeps triggering the alarm automatically all day until the battery is drained?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
