سعود فواز
2024-07-13 23:38
Has anyone experienced this situation? (The lights flicker while driving, the battery is fine, it's not the automatic headlights, and it doesn't happen very often. A roadside repair shop moved the headlight's fuse, but the problem still hasn't been solved.)
عبدالرحمن عبد الناصر
عبدالرحمن عبد الناصر2024-07-26 21:38
On the right side of the steering wheel, there are two knobs on the dashboard. One adjusts the headlight range, and the other adjusts the brightness of the dashboard lights. Give them a try.
MG GS, with over 60,000 km, recently having trouble starting the car. It requires several attempts to start. Once started, five or six warning lights come on, and when pressing the accelerator, the car doesn't move, can't go over 10 km/h. It often needs to be turned off or re-shifted. Sometimes while driving, pressing the accelerator doesn't speed up the car, but the engine sounds like it's in neutral. It also jerks when moving. Local repair shops are hesitant to fix it, and the 4S shop is too far away. I'm worried the car won't accelerate on the road, which could lead to an accident. Seeking help.
Due to work, I've moved to a rural area and I'm considering buying a four-wheel drive vehicle. My options are the Haval Raptor and Subaru XV. I want to ask friends here, is the trunk of the XV spacious enough? I have a two-month-old baby and often need to carry a stroller. From the photos, the XV's trunk doesn't look very large. Also, there's a common issue with boxer engines consuming oil—does the XV have this problem too?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
I've had my Ousheng for a year now, and after 15,000 kilometers, the engine started making a rattling sound like a tractor! I went to the 4S shop and they updated the software, which fixed it. Will this problem happen again in the future? I know a lot of people have faced this issue. If your car hasn't had this problem, please let us know. And for those who have experienced it, please share how you resolved it. 🙏🙏🙏
For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
