فهد حاتم
2024-05-07 22:07
Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
حسن لطيف
حسن لطيف2024-05-14 19:44
I still don't know the reason. [I want to be alone]
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
When the car starts, the ESP warning and engine fault warning appear, and it can't shift gears. It needs to warm up for half an hour before it can move. How can I solve this?
Hey folks, I have a question. My car can't shift gears. When the engine is off, the gear lever can move freely, but when the car is on, it's like something is blocking it, and it won't go into gear. It's a manual transmission, and I can't shift into any gear from 1 to 5 when the car is on. Does anyone know what the problem might be? Thanks 🙏🙏🙏🙏
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Is it necessary to hold the fuel nozzle manually while refueling to prevent it from shutting off? Does this happen to anyone else?
Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
