سلمان عفان
2024-05-06 21:41
Has anyone else had a half shaft failure at just over 20,000 kilometers?
عبدالرحمن جعفري
عبدالرحمن جعفري2024-06-19 23:21
Mine too, it's really rubbish.
Has anyone else experienced this? Is it just me or is it a common issue?
I have a 2019 GS5, and since early August, there's been a buzzing noise when driving between 60-100 km/h. It feels like I'm flying a plane, especially when I turn right, it gets louder. The dealership said it was a wheel bearing issue, so I had the bearings replaced, then the tires, and even the half shaft, but the problem still isn't solved. Has anyone else had this kind of issue? Please point me in the right direction. I don't want to keep wasting money and time on blind repairs. [About to cry]
Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
Is a 2017 model with over 60,000 kilometers, 1.3 manual, priced at 20,000 expensive?
Is there anyone with a 2019 model who has experienced a compressor clutch failure?
What should I do if the half shaft of my 2009 Jetta is worn out? The subframe and lower control arm were just replaced.
I need help with my 2019 1.5T Automatic Luxury Cabin version. I've been driving it for three and a half years, mainly in the city, and it's done over 31,000 kilometers. Recently, in the past two months, the fuel consumption has skyrocketed. When I fill up, the gauge shows 630 kilometers, but I can only actually drive just over 400 kilometers. Two months ago, I could easily drive around 550 kilometers. Does anyone know what's going on?
I've had my Cyrus for just over two months, and the main switch for the window lifter seems to be malfunctioning. When I press it down, the other windows can still move freely. Has anyone else experienced this issue? 😊
Does anyone feel that the idle vibration of the 2024 Macan S is a bit much? Just got the car, over 100 kilometers on it, and sitting inside feels shakier than my 4-cylinder BMW... Anyone else feel the same?
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
