طيب عبدالله
2023-11-21 14:33
Fellow Territory S owners, have you experienced a situation where the dashboard shows a message saying the transmission needs maintenance, and when you accelerate, the RPM increases but there's no power?
فهد طل
فهد طل2023-12-22 11:45
Replace the valve body.
فهد مجدي
فهد مجدي2023-11-22 12:51
Transmission issues, I got the same alert. Later it turned out the transmission chain was broken, or it could possibly be the valve body.
What does it mean when the V40 shows an "Engine Performance Reduced" message? My fuel consumption has already increased from 9.6 to 10.4 liters. It's really consuming more fuel.
Good morning, has any owner experienced the situation where the car doesn't move without accelerating after the annual inspection, and the fuel consumption increases? What could be the reason for this?
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
Is it normal for the 2021 four-wheel drive to show an icon on the dashboard with the front wheels tilted, or is it a four-wheel drive warning? The dealer says it's normal, but it didn't seem to be there before. 🤦‍♂️
After changing the drive shaft of a 12-year-old Korean imported car, it makes noise when you press the accelerator, but the noise stops after 2000 RPM. Fellow car enthusiasts, have you encountered this situation? How did you solve it?
Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦‍♂️🤦‍♂️🤦‍♂️
Hey fellow car enthusiasts, have any of you encountered a situation where you're driving and suddenly get a warning saying the clutch is overheating and you should stop and rest? Lately, I've noticed that the acceleration response feels sluggish and the fuel consumption is high. It's a January 2024 Porsche.
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Ford Ford Territory
Ford TerritoryAED 105,635Gasoline
