Does a transmission remain durable after being repaired once? If it breaks again, how long did it take before you had to repair it again? [facepalm]
I have a 2012 model Jimny, registered in September 2013, currently at 46,000 kilometers. At the end of May, the engine warning light came on once. I used a diagnostic tool to reset it, but it didn't specify the reason. I had maintenance done on June 2nd, and the engine warning light appeared again the day before yesterday, but it disappeared yesterday afternoon when I went out. Does anyone know what might be going on?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
I've been driving a 2015 ASX and need some advice. The car starts just fine, but once I pick up speed and then suddenly brake to slow down, when I press the accelerator again, it feels like there's no response at first. There's a sudden jerk before it accelerates, making the driving experience really bad. Could it be time to change the transmission fluid? It's been 7 years and 45,000 kilometers, and I haven't changed the transmission fluid yet.
4After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
5I was driving a Haima S5 1.6 CAT Creative Edition on the highway for about 6 hours, and suddenly the car couldn't accelerate. After stopping and turning off the engine for a while, it could accelerate again. What could be the problem? This has happened twice already, once on the highway before and once this year. When it couldn't accelerate, the car showed a fault code, but after parking overnight, the fault code disappeared. Has anyone else experienced this?
6My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
7Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
8I've had my 2021 Jeep Compass for three years now. Last year, it was parked for half a month during the New Year, and the battery died, so I replaced it. In March this year, it was parked for over 10 days, and the battery was dead again. I replaced it with a new battery, and in May this year, after being parked for 9 days, the battery died again. What's going on?
9Does a transmission remain durable after being repaired once? If it breaks again, how long did it take before you had to repair it again? [facepalm]
10The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
