حسين فخرو
2024-12-01 19:52
When the vehicle is cold started, there's a rattling sound like metal wires clanging coming from the engine bay. It happens almost every time, and I haven't pinpointed where it's coming from. Has anyone else experienced this?
حسين فخرو
حسين فخرو2024-12-02 20:08
[Crying][Crying][Crying]
حسين ظافر
حسين ظافر2024-12-01 21:43
The salesperson said this is a common issue. My car also makes a buzzing sound from the engine when it's started cold.
Whenever I accelerate my Phaeton 3.6, there's a sound like metal clanking coming from the middle section of the exhaust pipe. I can't seem to fix it. I had it checked, and there's nothing wrong with the exhaust pipe. The dealership mentioned it's a common issue. Has anyone else experienced this problem? Any solutions?
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
Is there anyone else experiencing a rattling noise from the left corner of the dashboard in a 2015 V40? I haven't been able to find the cause.
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
Is it necessary to hold the fuel nozzle manually while refueling to prevent it from shutting off? Does this happen to anyone else?
Hey everyone, does anyone else have strange noises coming from the front passenger seat or the trunk? 🤔
Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
Volkswagen Volkswagen Teramont
Volkswagen TeramontAED 137,100 ~ 215,000Gasoline & Petrol
