خالد أصغر
2024-11-08 12:47
When the speed is around 43, the headlights noticeably get brighter than before. What feature is this, and which lights are getting brighter?
نايف بارزاني
نايف بارزاني2024-11-30 00:24
I haven't paid attention to [I Want to Be Quiet].
نايف غازي
نايف غازي2024-11-21 09:31
Lane assist light. Turns on over 40, turns off under 40 speed.
I upgraded to high-end headlights on my Pathfinder, and they flicker when I use the start-stop feature. Is there a solution for this?
Hey guys, can the MG GT take up to 60 liters of fuel? Recently, every time I fill up, it's around 52 to 53 liters. Always feels like it's more than before.
Why does the right front wheel of my 2019 GA6 get about ten degrees hotter than the other three wheels after driving for a while? When I touch the hub, the temperature difference is quite noticeable.
What could be the reason for the headlights and brake lights turning on by themselves at night?
Have you noticed water droplets inside some car headlights? What's going on with that?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
When slowly accelerating at low speeds, the V60 B4 2024 model experiences noticeable jerking and dragging.
When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
I didn't drive for two days, and when I started the car today, I noticed the engine warning light was on. For the first ten minutes or so, pressing the accelerator only increased the RPM, and the speed stayed below 20. After driving for about ten minutes, when I pressed the accelerator, there was a humming noise, and the speed gradually picked up. However, the fuel consumption display kept changing even when the car was parked or just started and not moving (or maybe I hadn't noticed this before). Can anyone advise what's going on? Has anyone experienced this before?
Can the new Jetta's headlight cover, which is higher than the grille, be adjusted to be level? Any car enthusiasts who know about this, please give some guidance.
Volkswagen Volkswagen Teramont
Volkswagen TeramontAED 137,100 ~ 215,000Gasoline & Petrol
