Is it worth buying a lifetime warranty from Volkswagen, which covers everything except the three main components?
Is the warranty for the three electric components of this car limited by mileage?
Is the Jietu X95 Supreme Edition covered by a lifetime warranty?
For a 2013 used Mitsubishi ASX 2.0 manual, it's said that the main components are imported. After purchase, aside from consumables like engine oil and brake parts, would other repairs be particularly expensive? Or should I just use aftermarket parts? I've driven company cars with 1.3L, 1.6L, 2.4L engines, front-wheel drive, rear-wheel drive, and manual transmissions.
4How is the warranty on the three electric components? What about for used ones?
5The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
6I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
7Hi everyone, the electronic steering lock of my Chery Jetour X70 is broken and needs to be replaced. The 4S shop said it's no longer under warranty, so I have to replace it myself. It seems to cost several thousand. Does anyone know if the 10-year or 200,000 km warranty indicated by the lifetime warranty badge on Jetour still covers it? The steering system is an important part of the car. The car was registered in August 2020, so it's been almost four years. Does anyone know if this is still under warranty? Please help.
8What exactly is covered under the lifetime warranty that the manufacturer claims for the Roewe RX5 MAX?
92018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
10Has anyone purchased the extended warranty package from the manufacturer? It costs 2200 and includes 2 synthetic oil changes and air filter replacements, with a 5-year extended warranty for the whole vehicle. Is it worth it?
