Has anyone experienced a similar issue with a Teramont after driving over 28,000 kilometers, where there's a noise coming from the steering? The inspection suggests going through the process to replace the steering rack.
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
Has anyone experienced any abnormal noise when shifting gears with the 1.4T transmission? It's only at 28,000 kilometers.
4When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
5When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
6There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
7Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
8I experienced a similar issue with my steering column making noise and feeling stuck. The dealership suggested replacing it, but it's quite expensive, so I didn't go for it. How did you guys deal with this problem? Do you have any good solutions? My car is over three years old and has run more than 20,000 kilometers, and this issue has come up. I think there might be a quality issue here.
9Hey, fellow car owners! Have any of you experienced a loud creaking noise coming from the chassis when turning the steering wheel while stationary? I'm not sure if this is normal or if it's an unusual noise, but it's really loud and quite bothersome 😫
10I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
