سلمان حكيم
2024-12-03 15:28
When making a right turn in the 2021 Nissan Altima, there is a "da" sound. Not sure if it's coming from the rear or the front.
Front right wheel makes a noise at low speed.
Why does the engine compartment of a 2010 model, registered in 2011, with 83,000 kilometers occasionally make a "da da da da da da da" sound, especially noticeable when starting and just before stopping after driving?
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
Can you hear the engine making a "da da da" sound when accelerating your ASX?
Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
I've got a 2018 GWM GS7, and recently the engine's been making a "da-da-da" sound while driving. What's going on?
Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
Can I add CarPlay to the 2022 Nissan Altima if it doesn't come with it originally? Is there anyone who knows how to do it?
Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
