There's a "da" sound when turning right in the 2021 Nissan Altima. Not sure where it's coming from.
Why does the engine compartment of a 2010 model, registered in 2011, with 83,000 kilometers occasionally make a "da da da da da da da" sound, especially noticeable when starting and just before stopping after driving?
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
Can you hear the engine making a "da da da" sound when accelerating your ASX?
4Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
5Is there anyone who has experienced an occasional rattling noise while driving? It seems to be coming from the left rear door lock area, making a "da da da" sound.
6I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
7When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
8Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
9Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
10Can I add CarPlay to the 2022 Nissan Altima if it doesn't come with it originally? Is there anyone who knows how to do it?
