عمر له
2024-12-03 10:49
I want to ask if any of you have experienced the same thing. After driving around 18,000 kilometers, the front wheels make a hissing sound like there's a leak, but there's actually no air leakage. Does anyone know what might be causing this?
سلمان شهيد
سلمان شهيد2024-12-03 14:40
I currently have 18,000 and no issues. Maybe you're just being too sensitive.
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
When you slow down to stop, and the RPM suddenly goes up to around 2000 before dropping, it could be related to the transmission downshifting or the engine management system adjusting for some reason. As for the brakes feeling a bit soft, you might want to check the brake fluid level or have the brake system inspected for air or leaks. If anyone has more insights, please share. Thanks!
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
Is it worth buying a 2011 automatic high-end 1.5 with 110,000 km for 18,000? The front windshield has been replaced, and the rear air vent can't blow warm air. I didn't look into other details. I took a short drive and didn't notice anything unusual.
I am sincerely asking for advice from everyone: When buying Subaru oil filters, air filters, and cabin air filters online, which specifications are the same between Subaru Impreza, Forester, and Outback?
Is there any leakage on the right rear D-pillar? Is it caused by the air conditioning pipe like the Land Cruiser Prado?
17 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
