The door closing sound and vibration are quite strong, and the car shakes noticeably when closing the door. Are you...?
When driving slowly in the 150ltd, if you hear the sound of the electric pedal retracting or extending, it could be due to a malfunction or a sensor issue. Even if the car doors are properly closed, the motor sound might still be audible. It's best to have it checked by a professional to ensure everything is functioning correctly.
I just got the 2022 T8 top model, and the road feel is really strong. The steering wheel feedback is quite intense, constantly feels like there's a slight vibration. Also, when reversing at low speed with the steering wheel fully turned, there's some shaking. The dealership says it's normal. Could it be related to the tires?
When driving at low speeds with the AC on, the car, which has over 30,000 kilometers, experiences significant vibrations. This is particularly noticeable when frequently reversing or making turns. The steering wheel, door handle, and seats all vibrate. Everything is normal when the AC is off. Sometimes, when idling with the AC on, there's a loud buzzing sound that feels overwhelming to the ears and head! I always use 95-octane fuel. Have you encountered this issue? How should it be addressed?
4Hey guys, do you hear the sound of water sloshing in the tank when your Y shakes?
5Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
6When it rains heavily, I can hear the sound of water on the left door of my 2017 model. I can hear it while driving, but when I shake the door, there's no sound. Does anyone know where exactly the water is accumulating?
7Seeking advice from fellow car owners: 1. Is it normal to feel a slight vibration in the steering wheel when the air conditioning is on? 2. When using the standard + B mode, there's almost no brake dive, but when the auto hold is activated, the brake dive is quite noticeable. Do you experience this too?
8Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
9Why does the car beep three times when starting, like the sound when a door isn't closed properly?
10Hey fellow car enthusiasts, do you also notice that when you start the car in P gear, the engine revs quite loudly, usually above 1000 RPM? But once you shift to D gear, it drops below 1000 RPM and the sound gets much quieter. Is that the case for you too?
