فهد وحيد
2024-12-03 19:58
Hey folks, can anyone help me out? My car's right-side passenger door won't close with normal force. The left side just clicks shut, but the right side needs a bit more strength. What's going on?
علي بهاء الدين
علي بهاء الدين2024-12-04 11:38
Visit the 4S dealership for a look.
سلمان بهاء
سلمان بهاء2024-12-04 10:29
Check the lock switch mechanism to see if there's an issue.
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
Is the fog light above the taillight on the left side only and not on the right side for the Sienna Platinum version?
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
The car won't lock, and the side mirrors close halfway and then open again by themselves. How should I deal with this?
After maintenance, the car door suddenly won't lock! The side mirrors won't retract, and there's a clicking sound near the fuel tank.
