عمر تامر
2024-05-22 19:57
Why does the Taycan revert to normal mode after changing the driving mode settings and getting back in the car?
نايف زايد
نايف زايد2024-05-22 20:24
Default on startup every time.
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
Does anyone know why the suspension rises to the highest level when parked and then drops back to normal after a while?
Hey everyone, does anyone know why a car would suddenly brake uncontrollably for a moment while driving normally, and then go back to normal? Any ideas?
Why does the car often fail to unlock or start after changing the battery?
Does anyone know if it's possible to set the default to economy mode? My fuel consumption is too high, and I want to try driving in economy mode for a while. 🤦‍♂️
Is it normal to frequently hear a low-frequency buzzing sound while driving the Taycan?
Hey fellow car enthusiasts, could someone share a picture of the initial sound settings for the 2019 model with the Bose sound system? I can't seem to revert back after switching to scene mode.
Why was the control panel completely changed? Will it be added back later?
Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
Porsche Porsche Taycan
Porsche TaycanAED 362,000 ~ 835,200Electric
