Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Why does the Taycan revert to normal mode after changing the driving mode settings and getting back in the car?
4When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
5Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
6Is it normal that you can't accelerate when the tires are slipping?
7Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
8Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
9Is it normal for the 2022 Kicks to shake when accelerating from a stop?
10Is it possible to set the car to default to internal circulation instead of external circulation when starting?
