Has anyone experienced issues with the transmission solenoid valve on the URV?
What causes difficulty in shifting gears in a manual transmission? Has anyone experienced this?
Has anyone else experienced this? Is it just me or is it a common issue?
Has anyone experienced the transmission not shifting while driving the 2.0T model? Thank you.
4Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
5For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
6Has anyone experienced issues with the transmission solenoid valve on the URV?
7Has anyone experienced this issue with the 2022 Haval H6 3.0?
8Hi everyone, can anyone tell me where the carbon canister solenoid valve is located in the Territory? A picture would be great. Thanks!
9The solenoid valve keeps breaking. How's yours doing?
102016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
